Radiator hose routing on an '84 944
Lifetime Member
Lifetime Member
I need some assistance in assuring myself that some of the radiator hoses are routed properly now that I have put the radiator back in the '84. My area of concern involves 3 hoses and the hood latch cable. They all cross over/under each other in front of the air box and near the headlight mechanism. These include the small hose from the top right side of the radiator (as you face it) , the large hose from the same side that goes to the flange on the head (pretty obvious how this is routed) , the medium sized hose that goes from the front bottom corner of the expansion chamber snaking its way through this area until it is routed across the top of the fan shroud to the other side of the radiator, and finally, the hood release cable routing as it leaves a clamp on the top of the left side longitudinal (small hose mentioned first shares this clamp). They look fine as I have installed them with plenty of clearance from the headlight mechanism and also from the alternator pulley hiding under them but I have a managed to somehow have the mechanism snag the release cable once and also nick the medium sized hose on another occaision (my karma most likely). Never got one into the alternator pulley but there is a first time for everything...8^}
Jim - I can shoot a pic and email it too you -
Extras care on the placement of the upper radiator hose clamp - wrong alignment and it catches on the headlight linkages . . .
Steve
Steve
Steve
Steve
