Bad Coolant Leak!!
I have a bad coolant leak from back by the starter, what is this? It's on the back of the driver's side of the engine. How much will a shop charge to fix this??
I know there are a bunch of people that will freak out about the suggestion, but if I drain the system adn put pure water in it, will that save my clutch since I can't have this done right now?
I know... no boilover protection, no freezing protection, blah, blah...
WILL IT SAVE ME A $1500 CLUTCH?!?
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
I read some old posts and NO MATTER WHAT it looks like you don't want to do it yourself. Of course when I'm walking funny out of the shop for being REAMED I'll think otherwise!
Well, just to update this, it's not that bad - the valve with installation is only $180. Thats cheaper than I've ever comeout of the shop spending!
I GET MY BABY BACK TOMORROW!!!
yea, just replace the hoses (they are very difficult to get to when the engine is in) and th heater control valve before they break. The parts are dirt cheap and they can save you a clutch job when they fail.
There is a heater control valve relocation kit that you can put together yourself. You just need the hose from a later 16 valve car for the block to heater core, and then some hard line to move the vacuum line to the front of the engine, right by the oil filter. The later cars had the heater control valves in that location.
Good luck!
Dal.
Good luck!
Dal.
Originally posted by Peckster
$180 is a deal. But they'll probably find something else to increase the reaming while they're in there.
