Help! I stripped the oil drain plug!
I tried to change the oil in my 84 and the bolt was a 15mm (or so I thought) I stripped the heck out of it with the 15 so I think it might have been replaced with an english aftermarket part. now it is rounded beyond belief. how the heck do I get it off? I drove the car until the oil pan was hot and still no luck. I have been using vise grips and a hammer but it still wont budge. any ideas?
Judd, don't forget to try good ol' WD-40 sprayed well into the crease around the plug. Maybe even letting it soak overnight. It's worked wonders for me. I assume you have a replacement drain plug?
Then try with a 12-point 17mm socket.
If you are a welder, you could tack something on there to crank it off. Otherwise, you could file a slot to unscrew it, or try to force it to unscrew with a chissel and hammer. Or, pound a slighty smaller torx socket over it. Drill a shallow hole in it for an EZ-out? Vice-Grips can also work at times--especially if you file the edges flat. Heating the area around the plug with a propane torch (carefully to not screw up the pan), can help with any of the above. Or ice on the plug.
There is a special shaped head channel lock that will remove rounded nuts. It is able to get the bolts off where no vice grip would work. The head instead of 2 flat edges is shaped like a parrot's beak and slightly bent. Its not the easiest thing to find but I have never encountered anything that I couldn't remove with that channel lock even if it is completely round.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
I've had quite a bit of success removing stripped or broken bolts using left-hand drill bits (they rotate in the opposite direction from regular bits). Bolts usually come out even before having to use Easy-outs.
