homemade intercooler sprayer
I haven't been around in a while since I sold my 944 a few months ago and picked up a new WRX. For anyone who's interested in an update, my buddy fixed the 944 -- it wouldn't start cold, and it turns out the fuel rail was leaking (yikes!). 6 months and 0 fires later, it's as good as.. running.
Anyway, since I'm strapped for cash now that I spent too much on a brand new car on my military wages, I've been looking for things to improve the performance in the WRX for cheap. So I made a $40 intercooler sprayer which should be easy enough to put on your 951s.
Parts: (All from Autozone)
Windshield washer pump $13
10 ft 3/16" hose $5
zip ties $2
Some kind of button/switch $3
Nozzles $4
Wire $4
Pictures of the whole ordeal can be found here.
I checked high and low for nozzles that'd work - at first, when I found nothing, I epoxied plastic valve stem covers to the hoses and poked holes in them with a heated sewing needle (which turned out to be the second best nozzles I tried). I also tried nozzles for a pressure washer, which, of course, didn't work at the low pressure of the washer fluid pump. I tried both Walmarts in town, True Value, 3 nurseries, all the auto parts places, Home Depot and Lowes with no luck. Then I finally found them. The nozzles are actually made for irrigation, and I found them at a John Deere landscaping store for a buck apiece. The DIY I followed found similar nozzles at Walmart, called "Orbit Dripmaster," but they've all been put in the back to make room for Christmas trees.
Putting it all together is pretty straight forward. If you look at the next page of the pictures I posted, I put the switch in the center console in my WRX, next to the hand brake. This is where the roller for variable differential is in the STi. I took the power from the power mirrors right there and grounded it where the battery is grounded under the hood. The washer fluid reservoir in a WRX sedan has an open place for a pump that'd go to the rear washer in a wagon, so I just drilled a hole and I was good to go. In an STi, the ic water reservoir is in the truck so it won't be exposed to underhood temperatures, and judging by the temperature of the water I've noticed since doing this, that might be a good idea.
So.. does it work? It feels like it, but... I've been to the drag strip once since doing it. My first run I forgot to spray and ran a 13.94@95.98. I gave it a ~2 second spray each run after that and never met that time, but I came close. I'll attribute it to not letting my engine cool between runs. A guy on the WRX boards has a post IC intake temp gauge and said he's seen swings of as much as 25C with the sprayer. So.. there ya have it.
10 ft 3/16" hose $5
zip ties $2
Nozzles $4
Wire $4
Originally posted by Mike Markota
Heh, at least you havent completly abandoned us!
Sure it would work. Such a weird car.
I've got 4 years until I seperate from the military, give me a year after that to get on my feet and I'll get a Porsche, one way or another. Deal?
