Boge Inserts
Old 11-22-2003, 12:58 PM
jeeper31
jeeper31's Avatar
Default Boge Inserts
Does Boge make different inserts. Just got off the phone with a parts dealer who can get Boge inserts for $109.00. This seems cheaper than I have seen around and am wondering if there are different models. Are these the ones that came with my '84 944?
Old 11-22-2003, 01:13 PM
billybones
billybones's Avatar
The originals are not inserts they are the struts... You pull out the guts and drain the nasty oil . the insert fits inside, the cap holds it in. I paid about 55 dollars each.. been about 2 years though..HTH.
do an archive search, for vendors, pelican parts, tweeks, vertex, paragon pts.. They all can help you.. THese are the places to order online.. I have had good luck with all.
Old 11-22-2003, 01:55 PM
Skip
Skip's Avatar
There is only one type of original Boge/Sachs insert (#944.343.059.00) and that should run around $75/each. If that's $109 for the pair, that's a great deal... almost too good to be true. KYB inserts run just under $50/each, but you should do a search here to see what others think about them.
The insert is a standard style drop-in type with an external gland nut at the top. You can fit Boge, Koni, Bilstein, and KYB inserts inside.
Good Luck!
Quick Reply: Boge Inserts
