'74 - what should I pay?
I'm looking at this '74 914 2.0. It has had the same owner since 1978. Body is good and so is interior. It has been in storage for the last 10+ years. It was not prepared for storage. It runs but smokes. I am guessing the fuel tank and lines need to be cleaned of the old gas and the engine needs a rebuild- seems like it could use new seals. Also could use a little exhaust work. What do you think it's worth, what should I should offer?
Not running for 10 years? smoking? you are looking at a "pig in a poke", might be good/bad. Get a proper mechanic to look at it or you could be spending more on the fix than the car.
If you are into the dare, and assuming no rust, offer $1200-2000 tops. Rusty/sputtering cars are valued based on what is left, start at $400 for the block, $500 for the frame/interior parts. Even if a nasty car is -free- it may cost you more than a good one, once you are done.
Good luck.
Been there....
<img src="graemlins/a_smil17.gif" border="0" alt="[blabla]" /> <img src="graemlins/a_smil17.gif" border="0" alt="[blabla]" /> <img src="graemlins/a_smil17.gif" border="0" alt="[blabla]" />
Good luck.
Been there....
