Bleeding front brake
A 74 2.0 and I plan on flushing the brakes, the front caliper has two bleeding nipples, do you just use the top one? Never seen a caliper with upper and lower bleeder.
Dan
87 928 five speed
Dan
87 928 five speed
I would bleed from both although any air would most likely rise to the top bleeder. Once you get fresh fluid from the lower just move up. The rears are a bit difficult but you can reach the bleeders by reaching over the top of the control arm or take the wheels off.
