Dirty fuel tank
How do you recommend to clean a fuel tank for a Porsche 914 cleaned it still getting dirt in fuel filter. Should I consider replacement with the dansek tank is that a direct replacement
thank you
thank you
I used a product from Eastwood when doing my restoration project 20 years ago. I remember washing the inside of the tank with maybe some type of acid and then there was a sealant product that lined the tank.
Premium Dealer
and POR 15 makes a product as well, just remove strip the accessories from the tank, go through the top hole and brush as much debris out as you can then add the product, swish around then lit sit and do it again
