Turn signals/lights not working
New to me...so just need to know where to start.
Hoping it's just some bulbs...
Neither turn signal is blinking. Front or rear.
The left front side marker
Brake lights work.
Reverse works.
Also. need to sort out the horn too...it's not working.
Brake lights work.
Reverse works.
check the emergency lights to see if they work. If they do the turn signal switch is not making good connection, if they do not , check the turn signal relay on the back of the fuse block.
