My 1967 912 Build Thread
#242
Professor of Pending Projects
Just a word of caution and note to myself... Do not remove a part without first checking availability...
Seems that a lot of the parts for the steering column are no longer available (nla). I removed the rubber bushings at the bottom of the column (part number 901.347.795.00 and #7 in the diagram below), inside the trunk, and now I find that those are nla.
I will try to salvage the ones that I took out. Maybe install them upside down so that the compressed part goes to the bottom.
Photos...
[img]http:
Photos...
[img]http:
#244
These came in...
and with a little persuasion, cursing, tools, and technique... they went in
I will install the center inserts once those are zinc plated to protect from rust...
#248
I know that everyone is recommending that I stick with the original color... but I am so tempted to paint it in one of these two colors...
Aubergine
Orange
Or even Vesuvius, like the 993C2S I had... how I miss that car...
Colors of the era...
Aubergine
Orange
#249
If I were to change colors on my 912 (which I am considering) , I would pick Red or Tangerine maybe favoring the latter. However, since you are already red, I would stick with that. But it is your car and you should do what ever you want especially if you have no plans to sell it anytime soon,
#250
FYI the orange in your photograph is Signal Orange, not Tangerine. But Tangerine is a good looking color on a longhood. (It's a little bit more tomato-y orange.)
#251
I was wondering about that but I was chalking it up to my colorblindness....which btw is a good reason not to listen to my opinions on color anyway
#252
Color choice is always one of the hardest things for me. I tend to side with staying original just because if I were to change it to another color I would want zero trace of the old color. It also makes a difference on resale value, original color is always worth more. my .02 Either way you go, I love what you've done with the car and am excited to continue watching progress
#255
