Titanium stud kit for Porsche 912
Former Vendor
We now offer a titanium exhaust stud kit for Porsche 944, 944S and 944 Turbo.Our set is the perfect solution to future proof your exhaust manifold to cylinder head. Our titanium alloy studs will not rust after repeated heat cycles, and will be easily removed when needed
The stud - made in Japan to exact Silverlake specifications, the titanium alloy studs will not rust after repeated heat cycles, hence will be easily removed when needed. Ti6Al4V alloy is as strong as steel but 45% lighter.
The nut - originally designed for the aerospace industry, k-nuts are the most applied locking nuts in high-end motorsports applications, due to their strength, low weight and temperature and vibration resistance. These European made all-metal nuts will lock once torqued up and will never unscrew unless desired.
The washer - made in the USA to exact Silverlake specifications, the copper washer will not corrode nor bond to the titanium stud or the aerospace steel nut, making future removal easier. These corrosion-resistant washers will compress for a tight fit and further reduce the chance of unscrewing.
Here some pics of the kit, and the studs installed on a 997 GT3.
