85 slantnose turbo listed as clubsport?
I am looking at an 85 slantnose cab. when I run the vin on carfax it shows club sport. club sport was a wide body non turbo cab I believe. So I think this is a conversion. vin is WP0ZZZ91ZFS100441. does any body have any guesses what this car is?
Clubsport is an entirely different car. Based on the narrowbody 3.2 coupe, it was a stripped version produced in 1988.
You're probably thinking of the super sport, which is a name (commonly used in the UK I think) for the M491/ "Turbo Look" package.
As for the VIN, IDK, someone I'm sure can decode.
IIRC, M491 debuted either in 84 or 85. The early ones, especially in a cab, are quite rare so it is unlikely it started even as an M491.
VIN indicates this car left the factory as an '85, ROW, 911. Is it fitted with 930 calipers/rotors?
Also, not sure if this is a factory cab. 13th digit of US-spec cars is 5 for coupe, 6 for targa, and 7 for cabriolet. What does 0 indicate for a ROW chassis? Not sure. Does the options sticker indicate M491?
AFAIK, the only way to confirm factory configuration [e.g. turbo chassis, slantnose fenders] is via a CoA.
thanks guys. It does say club sport on car fax. It does have the turbo brakes. I think it was originally a coupe. It also has g50 5 speed. I think it must be a converted car.
