Original Tire Sizes 76-77 Turbo?
Getting different references for a US Car?
http://www.excellence-mag.com/resour...1#.UqqOpOKj0yU
http://www.automobile-catalog.com/ti...911_turbo.html
A Few Restorers said to Go with 195/65 & 215/60 15's
195/65R15
91W SL N2(Porsche) 180 A A 1356 lbs.
51 psi
10/32"
19 lbs. 5.5-7"
6"
8"
7"
25.1"
829
DE
215/60R15
94W SL N2(Porsche) 180 A A 1477 lbs.
51 psi
10/32"
23 lbs. 6-7.5"
6.5"
8.8"
8.4"
25.3"
820
DE
Pirelli Fortunately has sets for both combo's, question is which set was on a US Delivered car?
195/65R15
51 psi
10/32"
19 lbs. 5.5-7"
6"
8"
7"
25.1"
829
DE
215/60R15
51 psi
10/32"
23 lbs. 6-7.5"
6.5"
8.8"
8.4"
25.3"
820
DE
215/60 VR 15 and 185/70/15 tires (Pirelli CN36 optional) with gearbox type 930/30
225/50 VR 15 and 205/50 VR 15 tires (Pirelli P7's, M395) with gearbox type 930/32 (for '76, 930/30.12, limited slip) - different KPH speedo for Pirelli P7's
Seems it was the US only, as ROW cars had bigger tires.
Considering a 1975 Lamborghini Countach had 205/70/14 front and 215/70/14 rear, Porsche was ahead of the curve. The Lambo had 375hp at that time also.
For ‘75/76 930’s, Dunlop tires were standard with Pirelli CN36 tires as an option (185 front, 215 rear) with wider low profile P7’s as an option for RoW only (215 front, 225 rear). At that time, larger street tires were not available for 15 inch rims but the 930 flares (lateral base sections widened by welded-in sections - 1700 mm at front and 1775 mm at rear) were needed for homologation purposes so that much wider racing wheels & tires could be fitted for 934s and 935s. The 930 used 21 mm thick spacers at the front and 28 mm spaces at the rear mounted between the rim and hub to fill out the arches.
