86 Misses Under Boost
My 1986 has an intermitent miss under boost once it is warmed up. On occassion it misfires so badly the car "bucks" when I try to accelerate. When I let off the throttle and drop below the RPM range the turbo kicks in it runs fine.
I had a misfire across all ranges (cold or hot)of RPM (worse under boost) and just had the plug wires, coil, distributor cap and rotor replaced. It seems better but still has a misfire.
Any suggestions?
TKV
Any suggestions?
TKV
