Will the replacement of the stock air box with a K&N air filter (open element) work without any other modifications/changes? Any advantage to this mod? Any detriment?
Yes... The K&N air filter is a great upgrade as it eliminates almost all air restriction
don't need to male any other mods for it to work.
Pete,
1977 930
K & N makes a factory replacment air filter for your stock airbox, otherwise you should probably use the powerflow airbox with a k&n or S&B type cone filter.
best of Luck,
Pete
