Cam Timing and the Power Curve? Need Help
After searching past posts on cam timing I still don't understand the issue of cam timing. Posts have stated advanced timing improves the low end power and some say advanced improves the top end power. Can someone explain which is correct and how advancing or retarding actually works? Also, several posts stress that it is more important to get both sides of the engine timing the same. How close does one need to be?
