911 Turbo (930) Forum 1975-1989
Wheel balancing/ slight vibration in steering wheel
Old 01-06-2003 | 12:03 PM
ravenitesocialclub's Avatar
ravenitesocialclub
Question Wheel balancing/ slight vibration in steering wheel
Just bought a 79 turbo with 11k miles. Car is perfect except for a slight vibration in steering wheel around 60. Normally this is a question of balancing. I brought the wheels to a speed shop ( who know how to balance properly), put the wheels back on and still have the same shake in the wheel. What else should I be looking for?
Ryan
Old 01-07-2003 | 07:02 AM
GoodMojo's Avatar
GoodMojo
Cruisin'
Post
Some other things to check:
- Tires out of round or bent rim.
- Tie rods
- Ball Joints
Old 01-07-2003 | 07:51 AM
Geoffrey's Avatar
Geoffrey
Post
Don't forget the control arm bushings are 24 years old and might be bad.
Old 01-07-2003 | 02:27 PM
ravenitesocialclub
Post
Thanks guys,
Tires and rims are OK and have been verified
OFF I go to check the rest
Old 01-16-2003 | 12:43 AM
kevin911turbo's Avatar
kevin911turbo
7th Gear
Post
I had a similar issue and repacked and adjusted the front wheel bearing and the vibration went away.
They where loose when I started
Kevin
87 Turbo
Old 01-16-2003 | 12:55 AM
John from WA's Avatar
John from WA
Post
What about the road you are on? I was thinking that I had a similar problem as well until I happened upon a new stretch of asphalt.
Quick Reply: Wheel balancing/ slight vibration in steering wheel
