930 internals???
i was just wondering about the power you could obtain from a 930 engine (or 965/993tt, etc)
using strickly stock internals....
like adding a larger turbo, upping the boost slighty, (forget about lag) etc
Sameer,
I have a large turbo, intercooler, ported twin plug 930 heads, 3.2 Carrera EFI manifold and a Motec M48Pro running the fuel, ignition, boost control, and traction control (soon).
As an aside note, I would have spent the extra money and put a good set of rods rather than running stock rods with that much HP.
thats cool then....
think the first mods i'll make are larger turbo, up the boost a bit....in the hopeful sub 1000kg car it'll b a screamer with just a stock 3.3
just worrying about that tail happy rear end....ever heard of anyone doing away with the back seats and mid engine the car???
Unfortunately the engine still has the Porsche 3.3 7.0:1 compression pistions and cylinders. Like I mentioned before, the bottom end is basically stock.
The car is very fast, I've had it 170 with another gear to go.
![](http://boards.rennlist.com/upload/Geoffs930.jpg)
It is in fact a 1989 with the factory G50/50 5 speed and LSD. The body is all stock for now. Unfortunately I have to put a center mounted oil cooler on it and that will require a different front valance so the air will flow to it. I purchased a fiberglass 930S front and used a rear grill from a 78SC cut down for the center air passage, but really prefer the stock look. AND of course NY requires a front plate and they are a pain about it. Not sure what I'm going to do.
The car is pretty quiet since I'm running a Borla single exhaust exiting right side and a direct outlet from a HKS wastegate on the left side so it looks like it has dual tips. On the track the car flames now and then once the turbo is nice and hot, I get comments about it all the times. At night on the street, I can see flashes once in awhile too. Thats pretty cool.
Geoffrey,
It's beautiful is'nt it when you see the flash? I too usually get a lot of backfiring usually when I change after 4500revs. My friends tell me that it's like a 2 foot long flame and comming from both tailpipes, one on each side.
