I need help with correct rear fender grove/s
Hi,
I am restoring my '86 930 Turbo and need inputs from you guys re: my rear fender lip/groove shape. This is original metal w/o filler.
http://www.flickr.com/photos/85399024@N00/7580485430/
Right rear fender looks ok.
However, the left rear fender looks kinda strange. (look at the lip/groove).
http://www.flickr.com/photos/85399024@N00/7580484692/
Does this look normal?
Is left really a little different from right?
Should I "fix" the left portion with filler?
Appreciate inputs from experts here.
Thank you.
Thank you.
Last edited by luial; 07-16-2012 at 02:32 AM. Reason: having trouble attaching/posting pics
I wasn't sure if I was seeing it right before but it does look like arc of the left rear lip is not as circular as the right rear lip. It actually almost looks like a slightly flattened circle and the distance between the inner and outer radius gets wider in that range too. Maybe I'm imagining it because you suggested it,though.
