Delete
hahaha on my 84 I've got the same disconnected wires on the right (not sure on the left). Noticed them last night.
I also have a connector to the right of the brake cylinder that if I wiggle/press together tighter it makes the horn go off like an alarm!
The one on the left plugs into the back of the solenoid that is in the picture, I believe. There are two such solenoids on later models, one of which is part of the air injection system and the other I think has something to do with timing retard delay when first starting the car. Neither of mine are connected, and my air injection system is removed. Not to worry....if your car's running fine, forget about it.
The other wire in your picture, I can't be sure of the location because of the closeup. Where is it located?
