New 930 Owner in Lithia, FL
If you are going for the fire rings, loose this "old school" idea on steel fire rings and talk to Neil Harvey at Performance Developments. I had steel rings in mine and those suckers leaked, not matter how perfect the mating surfaces. Once I found Niel, he set me strait - not a single hint of leakage, nothing, dry as a dessert, hard boost and all, I cannot even begin to express how clean they are at the sealing joints, all six of those suckers.
uninformed gas bag
(contemplating on whether gas bag is one or two words)
agreed
more pics
rod brg clears are within spec!
turbo oil pump clean & almost ready to go
rockers all need to be resurfaced except 1 that's too far gone
Oil pump key
I'm looking for an oil pump key to fit the 5mm wide keyway for the oil pump drive shaft that locks in the gears on the scavenger side.
Also, ran outta picture space. Do I need to delete previous pics in order to upload more?
Thanks,
RC
Thanks,
RC
