911 Turbo (930) Forum 1975-1989
Turbo hubs vs non turbo hubs
Old 02-20-2011, 02:40 AM
Twin Turbo
Twin Turbo's Avatar
Default Turbo hubs vs non turbo hubs
Looking to run a deeper dish rim on my 89 turbo, what is the difference in size from the factory front hub spacer of a turbo to a factory 911 carrera front hub spacer, would that be the right way to gain extra space, I believe there about an inch difference. Any info would help,
Thanxs
Old 02-23-2011, 11:15 AM
strudel
strudel's Avatar
The Carrera didn't use a spacer, only certain year turbos, and that would have been a 1" spacer in the front, and 2" rear. If your going to go to a wider wheel with more off set to the inside, be sure to check the clearance between the inside of the tire and the shock cover.
Quick Reply: Turbo hubs vs non turbo hubs
