new memeber 930 project
#61
Ended up going through some DOM trying to make some front down tubes that hugged the front pillars. After 2 attempts, I decided to go the normal route.
Finally got the car off the rotisserie for a bit so that I can start the cross bracing.
![](https://forums.pelicanparts.com/uploads19/IMG_01081323046997.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01111323047039.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01101323047073.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01091323047105.jpg)
Done for this weekend, I might pick away at the side impact bars and dig into the rear this week if I get out of work at a reasonable hour....
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
#62
Put in some hours today, it's crazy how long it took me to cut and fit 7 pieces... but after a long frustrating day I got the side impact cross bars done and the under dash bar too.
![](https://forums.pelicanparts.com/uploads19/IMG_01141323494126.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01151323494158.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01161323494185.jpg)
#64
Back in the shop tonight and got the cage roughed out and tacked in.
A little smokey from the welding and cutting....
![](https://forums.pelicanparts.com/uploads19/IMG_01261324017198.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01271324017242.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01281324017273.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01291324017305.jpg)
looks like a jungle gym in the back seat now.![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![](https://forums.pelicanparts.com/uploads19/IMG_01301324017334.jpg)
Car is back on the rotisserie so I can finish my welds.
#65
Spent some time in the shop today and go the cage finished. Would have got it done earlier but I ran outta gas for the welder. Plus I didn't like the way one of my braces came out and I went a different route with the roof braces. It take a lot longer to cut out a tube after it is finished welded in. ![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
![](https://forums.pelicanparts.com/uploads19/IMG_01341324183282.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01351324183419.jpg)
Got the donor roof inside and finally started to get some work done on it.
![](https://forums.pelicanparts.com/uploads19/IMG_0135a1324183480.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01361324183514.jpg)
After about 10,000 spot welds I was starting to see dots and called it a night.
![](https://forums.pelicanparts.com/uploads19/IMG_01371324183737.jpg)
At least I feel like I am moving forward and the roof is back on!
#66
Got most of the passenger side rain gutter done then ran out of Argon mix for the welder.
![](https://forums.pelicanparts.com/uploads19/IMG_01471324909313.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01601324909364.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01611324909416.jpg)
Seeing as there is no welding supply places open on Christmas, I decided to do some paint removal on the roof.
![](https://forums.pelicanparts.com/uploads19/IMG_01631324909571.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01641324909620.jpg)
Looks like the car was completely stripped at one point and a real heavy coat of primer filler was used, then primer and it was sprayed with a single stage red, but not body filler. so I am happy about that.
![](https://forums.pelicanparts.com/uploads19/IMG_01661324909661.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01681324909690.jpg)
#67
So apparently every welding supply place in my area takes the day AFTER Christmas off too. Due to this, I was out of my Argon mix and coudn't get any more welding done on the rain gutter delete so I decided to look at another project today.
Trying to figure out where to put this!![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![](https://forums.pelicanparts.com/uploads19/IMG_01741324932512.jpg)
After a lot of apprehension I pulled out the plasma cutter and went to work.
![](https://forums.pelicanparts.com/uploads19/IMG_01691324932578.jpg)
![](https://forums.pelicanparts.com/uploads19/IMG_01711324932661.jpg)
The fit is pretty good, gets more weight off the rear and into the nose.
![](https://forums.pelicanparts.com/uploads19/IMG_01721324932784.jpg)
Now that it is roughed in I can figure out line routing. I am planning running the supply line through the cabin and building a metal shield to cover it and also making a panel to complete the fire wall up front.
![](https://forums.pelicanparts.com/uploads19/IMG_01731324932739.jpg)
#69
Ok, back in the shop this weekend. I am cutting out the 930 harness ( I have the 87 as a back up) in preparation for getting the chassis primed. I am deleting a bunch of items and the factory hanress will either get a diet OR I am planning on going this route with wiring Painless Performance: 12 Circuit Universal / Streetrod Harness / Non GM Keyed Column . Seems like an easy way to update and simplify the system. Has anyone worked with this product?
Update,
What a pain in the *** this harness was to get out. I think I'd be much better off running a new harness.
Update,
![](https://a8.sphotos.ak.fbcdn.net/hphotos-ak-snc7/419063_2736472168834_1168236990_32251111_1853977887_n.jpg)
#74
got my torches back from the repair shop, what better way to break in the torches than working on the Porsche?
![](https://forums.pelicanparts.com/uploads20/IMG_02501330636828.jpg)
Just a little heat and the new tool took the ball joint castle nut right off
![](https://forums.pelicanparts.com/uploads20/IMG_02511330636887.jpg)
Time for powder.....
![](https://forums.pelicanparts.com/uploads20/IMG_02531330636941.jpg)
![](https://forums.pelicanparts.com/uploads20/IMG_02551330636966.jpg)
![](https://forums.pelicanparts.com/uploads20/IMG_02561330636995.jpg)
35 minutes and I'll see how good I did.
#75
One down, one to go..... Looks gray, but it's an aluminum satin.
![](https://forums.pelicanparts.com/uploads20/IMG_02571330642120.jpg)
![](https://forums.pelicanparts.com/uploads20/IMG_02601330642170.jpg)
New Ball joints are going in later tonight.
All done, Ball joints in and complete, ready to install back in the car.
![](https://forums.pelicanparts.com/uploads20/IMG_02631330653930.jpg)
![](https://forums.pelicanparts.com/uploads20/IMG_02621330653899.jpg)
