Whats Faster ?
Can we take the bikes out...... I have been without 2 wheels for a few years now... But my helmets are waxed and clean
It is much cheaper and simpler to modify any of the new generation cars to the 930 due to the CIS limitations, engine efficiency and electronics. Consider the performance of the BTR with all its mods, yet the stock 993TT still beats it...Move to an ECU flash on the 993TT and you get the performance of the 993TTS, check out the gap on the chart. No matter what, a newer generation engine with simply an ECU flash will bring much higher HP/$, that's the sad truth for us aircooled fans. :-(
Sometimes it seems people willfully ignore the details of the OP's question - and reason for starting a thread - in order to get their opinion in on some unrelated matter. In this case, apparently people feel the need to state the obvious, which is that the newer cars are faster and easier to modify. That has nothing to do with the OP's question, but I guess it makes you feel better to chime in.
OP, There is a big difference between the slighlty modded CIS 930 and the newer stock models, when you step on the gas pedal from 30mph and go through the gears
Pcar964, I hope the above was simplistic enough for you to understand.
Slownrusty, thanks
Slownrusty, thanks
Newer is almost always better, faster, more expensive... But does it really matter? Newer cars (post 993) are soul-less compared to the cars designed in the original Porsche mould. I wouldn't mind owning a late model water pumper, but only if I could keep my air cooled cars. It doesn't really matter to me how fast they are as long as I enjoy them...
You guys will have to include me in that conversation... it ain't nothing like the thumpty thump, thump of Hawg as opposed to the ziiiing of a ??
Onboost,
Not all non-Harleys go ziiiing, as you put it....Mark & I have already come to an understanding on this matter....
I once started a thread about concealed carry pistol permits & 930 owners, as well as a thread about how many 930 owners are named Mark. Both of these went WAY south, WAY TOO fast... there is no way I'm starting anything about Harleys...In my best Bush Sr. impression........"Not going to do it, wouldn't be prudent"
Mark
Mark
To bring the thread back on topic, I have driven a 996t. It was definitely faster than my lightly modded 930. My 930 was a bit scary to me when I first acquired it...not so much after I got to know it. The 996t was frighteningly fast...soil your underwear fast...stupid fast. And it was all too easy, with little drama.
I am rebuilding my 930 now...modifications are going from mild towards wild so maybe it will scare me again. For the $$, I could have a nice 996t. For a bit more (which I know I will eventually spend on my 930), maybe even a 997t. But I don't want one of those. Why...too easy with little drama.
