new project
#31
I wanted a wing that had intake ducts on either side so I can "ram" cold air onto my intake filter but the only one I'v seen that has them was the Getty Design GT 1 wing. It doesn't look like the 3.8 wing you have has them right?
#36
I want to modify it somehow so the tire clears it and put it back in so the headlight washers work even though I never use them. Will also give back the larger winsheild water storage capacity.
Anyway, I was pretty surprised that with the big washer bottle out of there the little one for glass getergent up next to the mastercylinder which has it's own 12 volt pump on the bottom still sprays the windheild with water when you press the little momentary rocker switch below the headlight washer switch on the dash.
So I took it out (only one little screw and a tab holds it in place) and cleaned the slimy science project that has been growing in it and filled it with water.
There's an electronic timer somewhere in the car that shuts off the water pump for the little washer bottle after about 2 seconds so you have to press it repeatedly to keep shooting water on the windsheild to clean it good, but it works.
My car is an '87.
#39
I recently removed the big one in the left front fender because my 235/40x18 left front tire rubbed it on a hard right turn.
My car is an '87.
My car is an '87.
