I have a new shop working on my 930
#46
Shop Rat
#47
Shop Rat
I took some pictures of the (finally) clean car this weekend:
![](http://i34.photobucket.com/albums/d106/jculpjr/930hdrreduced.jpg)
![](http://i34.photobucket.com/albums/d106/jculpjr/enginebayreduced.jpg)
New shifter **** that Tracy made due to the stock one breaking upon removal:
![](http://i34.photobucket.com/albums/d106/jculpjr/shifterreduced.jpg)
![](http://i34.photobucket.com/albums/d106/jculpjr/930hdr2reduced.jpg)
#52
Shop Rat
We think the oil may be coming from the oil tank vent. I have zero smoke at start-up, so there is no oil accumulating in the turbo this time.
Thanks for the kind words everyone.
#55
"I have zero smoke at start-up, so there is no oil accumulating in the turbo this time."
You probably already know this, but f your turbo has oil leaking past the hot side oil seals into the turbine housing it wouldn't instantly smoke on a cold start. There is not enough heat there yet.
The exhaust is hot enough as it leaves the exhaust ports but by the time it goes through the cold headers, and cold turbine housing it is not hot enough to burn any oil that might be pooled in the turbine housing right away.
The motor has to run a little bit before the turbo housing and turbine gets hot enough to start burning off any oil that might be there already.
If oil is pooled in the compressor side, then it's going to be blown all through the intercooler, BOV, TB, and intake manifold and will be somewhat pooled in all the low spots. Then it will smoke on a cold start and even more as everything gets hot.
I hope your turbo last like it should this time.
Hope mine does too.
Jim
Hope mine does too.
Jim
#60
Shop Rat
I took the 930 in for a fender repair (looked as if someone intentionally opened their door hard into the drivers rear fender) and Tracy took some time to fine-tune the Autronic programming. I was getting some jerkiness on throttle tip-in. The fuel was a little lean, so it was fixed and drive ability is much improved.
I now have heavy wheelspin in first starting at about 4K rpm and the tach naturally races toward redline at that point, so I have to be careful. Wheelspin shows itself again in second at the 4500 rpm level. The car is a real handful now, but very fun.
Here's a dyno graph of the latest pull:
It's making about 442 to the wheels and with about a 17% driveline loss, it's making about 517 to the crank. There is only on real blue line on the graph, the others were added by my 2 yo daughter with a crayon. Boost was at 13 pounds.
![](http://i34.photobucket.com/albums/d106/jculpjr/930dyno.jpg)
