911 Turbo (930) Forum 1975-1989
car won't start
Old Sep 5, 2008 | 12:46 AM
blackboy's Avatar
blackboy
Default car won't start
On Saturday I took aride out to Jersey for the Grand-Am race at NJMP. The trip down was uneventful, when I decided to leave about 5 hours later the car started and then immediately stalled.
After repeated attempts at starting the car with no success I asked some guys to give me a push start. The first two attempts did not work but on the third try it started.
I drove it most of the way home with no dramas until about a mile and a half from my house it stalled while waiting for a light and would not start again.
I called a tow truck and he dropped the car at my house and we pushed it into the garage until I could have a look at it.
I have determined that it is not a fuel pump issue, the engine cranks but will not start. It seems as if it is a lack of spark problem.
Can someone suggest the probable causes that could be preventing the car from starting and in what order I should be going to determine the cause of the problem.
Old Sep 5, 2008 | 06:40 AM
A930Rocket's Avatar
A930Rocket
The usual suspects: CDI box (can you hear it whine with ignition on?), cap, rotor, plugs (try first), plug wires, corroded wires, fuses, fuel pump relays...
Old Sep 5, 2008 | 07:00 AM
Kirk930's Avatar
Kirk930
I would check the coil first.
I had three Bosch units (made in Brazil!) fail on my SC (sold) within a year. Went with an MSD coil (which is now on the 930) and never had a problem since.
Old Sep 21, 2008 | 12:01 AM
blackboy's Avatar
blackboy
I changed the cap, rotor, and coil today and it still would not start. I pulled the coil wire off the cap and had someone crank the engine to see if there was any spark but there was none.
I am beginning to think it maybe the CDI box, is there away of testing it to see if it is working or not? Thanks.
Old Sep 21, 2008 | 02:53 AM
boostfix's Avatar
boostfix
This could be an intermittant problem with your ignition delay relay. This relay controls power supply to your CDI. To test this, remove the relay and jumper out pins 30 and L on the socket this will ensure that power will get to your CDI with the ignition on.
check out my thread on Pelican - post #10
good luck!
Old Sep 21, 2008 | 08:11 AM
nathanUK '81 930 G50's Avatar
http://forums.pelicanparts.com/showthread.php?t=419339
This should help. There are also some figures in the manual if this doesn't help you.
Old Sep 21, 2008 | 10:14 AM
Cajun's Avatar
Cajun
Sounds like the CDI box to me. My car suffered from the same problem a few years ago. It would run fine for a while, and then without warning it would shut off just like if someone had removed the key...
Eventually the problem got progressively worse. I would definitely check out the CDI unit...
Keep us posted...
Old Sep 21, 2008 | 05:10 PM
It's quite common for ignition to work when cold and then cut out as things warm up. If that's the case then it probably is the CDI unit.
Old Sep 21, 2008 | 11:38 PM
blackboy's Avatar
blackboy
It just won't start at all now, engine cranks but that's all.
Old Sep 22, 2008 | 01:40 PM
Do the checks with a meter I posted on Pelican and let us know the outcome.
Old Sep 23, 2008 | 11:08 AM
boostfix's Avatar
boostfix
...he must be in the garage with printouts of porsche threads and a multi meter in hand...
Old Sep 23, 2008 | 09:27 PM
blackboy's Avatar
blackboy
I will definitely post the results when I have them. I will be away for awhile so it may take a week or so to post. Thanks again for all the suggestions.
Old Oct 15, 2008 | 09:51 PM
blackboy's Avatar
blackboy
When I try to take readings at the coil and at the cdi plug, should I be taking them with the key in the on or off position or while someone is cranking the engine. I am not sure on the procedure for testing.
Also, I was reading in the workshop manuals that if there is a problem with the tach this could be preventing the car from starting. Does anyone have any info on this last part? Thanks . I will be troubleshooting on Saturday.
Old Oct 16, 2008 | 03:02 PM
f you are referring to my readings I posted for you then you certainly don't need the keys! Unplug the CDI and take readings with an ohmmeter.
You would only need the ignition on if you were checking the voltages which is not a good idea with ignition.
Try unplugging the tach, I've heard this can cause the car not to start. If it starts it has been said the tach is at fault. I think it has some kind of diode in it.
Old Oct 17, 2008 | 12:02 PM
blackboy's Avatar
blackboy
How do you disconnect the tach?
