Show me your transmission cooler setup
OK, rather than me try to figure it out from scratch - what have you done to install a cooler in your 930 on your 930 box?
I've got the Tilton pump - thanks PurpleHaze - and now I've just got to figure out the best place to mount the pump, the cooler, route the lines, etc.
So if you've done it, I'd like to see it:
1. Where did you mount the pump?
2. Cooler mount point?
3. What size lines?
4. Did you pull fluid out of the drain plug area of the tranny? and where did you pump it back in?
5. Did you use an external tank to hold more fluid to compensate for the fluid required to fill up the lines/cooler/etc.
Any other info you've got, I'd like to hear...
(BTW I did a search, but didn't really find what I wanted to see)
Thanks,
Brian
3. What size lines?
Thanks,
Brian
Yeah Geoffrey, I had seen your pics both on here, and on Pelican. But I wanted to see other options.
Thanks.
And thanks Van. That gives me some more ideas.
Any particular info you have regarding the size of that cooler?
BTW - how does that particular tranny vent? Because of the pump, is the vent no longer needed? Just curious since the tranny is flipped upside down, how does it vent...
Thanks guys.
If anyone has any more pics/options keep them coming.
Brian
Thanks.
Thanks guys.
Brian
