A/F and Temp
A/F and Temp
The weather here in NY varies greatly this time of year. One day it could be 55 the next 85. I have noticed the cooler it is the higher my A/F ratio is. For instance at 50 deg say at 6000 rpms it could be 12.4 and the next day say its 75 deg, my A/F at 6000 is 11.8. I am assuming this is normal. What a pain in the *** CIS is. I am debating on this Digital warm up regulator.
Yep, it's all about air density...colder air being more dense. Unfortunately with CIS, I don't think there's a provision in the fuel delivery system(s) for taking air temp into consideration. Engine temp yes (by the WUR), but air temp...?
I re-tune my CIS every summer and winter. Most of the discrepancy can be taken out with a 1/16 turn of the idle mixture screw. Unless you run the ragged edge of tuning it is not that noticeable.
I have read that the mixture screw really only impacts the A/F ratio at idle. Is that not the case? Does it impact fueling throughout the rev range? Need to get me an AFR set up so I can play with that!
John,
you think too much...just drive the damn car! My AFRs do the same thing as long as they're in the safe range I don't worry.
By the way, I went to Hooked on Driving's Pocono North DE w/ Rik yesterday. There were suppose to be 5 of us from CIM, but only 3 showed. You should come next time.
Scott
Scott
