1986 930 engine oil cooler
Just pulled my 1986 930 out of winter storage and fired it up and the engine mounted oil cooler sprung a major leak on the passenger side just above the hose, is there a rebuild you can do on these or is it replace only item ? If it is a replace only item is there a better performance upgrade other than OEM ? any help would be much appreciated.
Laszlo
Laszlo
The engine oil coolers just went NLA, Behr is no longer making them and Porsche no longer has them available. This is a very recent occurance so you may be able to find some old stock if you act quickly.
Vertex has an aftermarket cooler listed:
Oil Cooler, On Engine
Manufacturer: Aftermarket
Engine Cooling : Oil Cooler & Related Parts
Sku #: 4539 Part - No: TMP9801
Manufacturer: Oe Manufacturer
Sku #: 1397 Part - No: 91110704100
Your Price: $1,145.00
