Piston Kits
Not Forgotten
Came across this in my search for bits, looks like a good deal if they are in good condition http://cgi.ebay.com/ebaymotors/Porsc...spagenameZWDVW
How can that look like a good deal? There aren't any specifications of what the pistons and cylinders measure out to be. There isn't pictures of the skirts, and you don't know if the wrist pins are tight in the wrist pin bore. In short, unless a machine shop has measured these and the data is available, consider looking elsewhere.
Not Forgotten
Sorry Geoffrey, i just came across them and thought he might be interested in checking them out, i'm sure he'd want to qualify whether they are in good shape before he purchased them.
If they are in good shape and everything checks out, are they a good deal?
I have no idea who the seller is, i'm in the UK for starters, just trying to help out
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
I have no idea who the seller is, i'm in the UK for starters, just trying to help out![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Currently, I have RUF 3.4L P/C's and am interested in replacing with comparable components.
I appreciate any and all feedback. As I too am just learning about these cars...
Thanks,
Jitters
Keep it coming...
Thanks,
Jitters
Jitters,
To help you out a little if you pm me I can get you the name an number to the previous owner of the car and let him know you are calling. He can give you some more details about the engine.
Just to be clear, I would not use a JE piston in any application, there are far better pistons out there. I have no experience with the Nickies cylinders, however, I am very close to trying a pair myself. From everything I have read and heard, Charles has a good track record and the design of his cylinders makes sense. They are Billet and made from I think 2618 Billet.
Okay Gents,
I've got a question and please go easy on me...Since only 2 of the pistons and barrels are bad, is it necessary to replace the others that are still good?
Be nice please...
Jitters
Be nice please...
Jitters
Probably my dumb VSS...After I had the new turbo installed, I was messing around with the boost controller. Couldn't leave well enough alone...I believe I adjusted it to high, thus the reason for the broken rings and the bad pistons...I heard what apparently, was what I believe is detonation, so I immediately adjusted the boost all the way down...but by then, I'm sure the damage had already been done...Shortly after that is when I noticed the blow-by...
Jitters
Jitters
