OBX headers--oh my...
#32
Guys, these headers do offer value and I am the first one to say that I have bought them and tested them. However, believe it or not most of us are just buying these headers and taking them to your indy and having them install them. Many times with a new turbocharger that has my name on it. Guess what.. It doesn't live long. Rocket's picture is reproduced many times a month, I'm sad to say.. It's a pain in the ***, repairing these units that shouldn't have this damage. Heed my warning, don't rely on the Indy to spend the time to clean the headers. Please pay attention to the O2 sensor bung. They have ground away a portion of the bung. When the new O2 sensor is threaded in, material/threads break off and pass into the hot side of the turbo.
If possible.. Clean and re-clean.. Pass rags thru the primaries, you'll be amazed at the crud/metal/grinding dingle berries and more. I then use a Dawn dish soap and a baby bottle brush that is modded to pass thru the primaries (you can only pass it so far).. Install your old turbo and put some miles on the headers.
BTW, these issues aren't isolated to just foreign made units..
#33
Hello Kevin,
would you realy recomend putting the O2 sensor before the turbo in this bung?
Or is it to put your US original O2 sensor in there?
Here we tend to put our wideband O2 behind the turbo.
regards
Falk
regards
Falk
#35
Rather than meticulously attempting to clean all of the grit, weld spatter, debris, and what have you from inside these headers, I'd recommend having them extrude honed. It will cost a bit more, though you are still saving a ton over a typical expensive set of headers. While I would still check for debris after extrude honing (I think it would be pretty much impossible for any to remain), it will smooth things out considerably and should clear up 99.9% of the problem. To me this seems a much easier route and for a complete set of headers I don't believe it should cost more than ~$200-300 maybe.
#36
Just got my headers today and i inspected them not bad for 400 to my door i found one piece of metal just hanging on in the wastegate pipe near the turbo flange and theres a fair bit of polishing compound ? or cutting wheel debri ? in the header and oil tank , i did some test fittings the wasegate half of the header needs a little tweaking to line up the other half of the system fits well noticed one of the tips of my air injectors on the #3 head was chipped about a 1/4 inch that could kill a turbo easy i guess i got lucky and it broke off in small pieces time to loose the emissions crap
#37
Got them from ebay ,379.00 with shipping 400 the company is called tuning depot and then albert at going super fast gave me a great deal on the gaskets and oil line
