Need A Clutch
Need A Clutch
Put headers & Zork on my 930. You guys were right, the headers made a HUGE difference in the power on my car...especially since I had all the other mods. The car is seeing 1bar all day long now!!!
Anyway, I just found out that my clutch does not like HP as much as I do. The clutch is slipping badly under a load in 3rd & 4th and it is doing it sometimes in second...always under a full load/full boost.
Where do I need to look for a new clutch? Any suggestions? How much $$$ should I expect to spend?
Thanks again...
Cajun
Thanks again...
Cajun
Been there done that. Bolt on all these goodies and get the power just where you want it...then damned if the clutch can't handle it. I've had to feather the throttle slightly in order to run full boost without slipping, which takes a lot of the turbo rush out of the whole experience. That's why she's in the garage as we speak, sitting about 30 inches in the air right now, waiting for me to pull the motor and put in the Kennedy PP.
When the snow's gone next spring....look out!
Update:
My mechanic has recommended the Porsche replacement. I don't recall the name off the top of my head, but it is the same clutch Porsche originally put in the car.
I am going to be doing some research this weekend...I am interested in finding out what my aftermarket options are. My plan is to continue to mod the car, so I don't want to have to worry about a clutch again anytime soon.
Whoa - there's a performance minded guy. In your research, you'll find more options. I think the Porsche pressure plate is a Sachs, which you can buy in the after-market at about 2/3 the price if you want to stick with (near) OEM. Or look at a KEP unit for less than half the price and equally effective.
I deff will i have everyone i know trying to work on this issue but they come up with options that r not good for the street. I am currently waiting to hear back from some cluth guys if anything positive i will be sure to get you guys the info as well.
"Good luck on your clutch saga. Only feedback I can provide is to beware SPEC. They make fine clutches - when they send you the right one. Had some pretty ****ty customer service with them and my former //S6. And they went as far as using an OE pressure plate and scraping off the @#$%^ OE serial numbers!!!"
Seriously the worst customer service I've yet to experience. They sent me the wrong unit then were VERY reluctant to swap it for the right one, and even then there's the "serial number" issue I mentioned. WTF? Cost me ~ $500 labor for an extra trans R&R when we found the unit they initially sent me wouldn't disengage. F'd up stuff.
Least the clutch that I finally got WAS in fact pretty decent. I went with a Stage 2.5, carbon / kevlar. Took ***all of*** ~ 11k to break the sucker in though. VERY grabby until then, chattery. Once it did it grabbed like a drunken prom date, very nice.
I'm currently running a center-sprung OE unit in the 930, it feels great. Not sure how it'd handle big power though - others here waaaaaaay more able to opine there.
Good luck!
-Paul
www.krasusky.photos.us.com
Hey Cajun,
Just had my clutch replaced in mine. Didn't want to go with stock Sachs setup due to the mods on my buggy. So I went with KEP's stage II kit. Actually met Mr. Kennedy himself, very nice man. The shop is located in the Palmdale/Lancaster area of southern Cali. Roughly spent just over a grand for the complete kit, Clutch Disc, PP and bearing. Works great. I also opted to replace the flywheel with a Fidanza lightened unit, again works great. Totaly satisfied with the entire upgrade.
Good luck with your decision.
Jitters
Jitters
Sorry to here about the PCAR...Just went through the same ordeal myself...and now I've got these new issues. BTW, did you ever get an opportunity to email that information?
Jitters
