total electrical shutdown
Where is a good place to start? Car is an 82 930, I was driving 40 mph and had a total electrical shutdown right in the middle of the road. No guages, lights, windows or radio. The starter does not turn, the hazards do not work and the electromotive crankfire led is not powered. Am I correct that all power runs through the ignition switch? Fuses are all intact. Cable running from battery to the starter was just a little warm when I went into the boot. Sidebar, I did install a new hi torque starter two days ago, could this have any impact? Not exactly what I had in mind when I went out for a spin this evening...
Tom
BTW, when you call the tow in make sure you request a flatbed with the additionad boards, this would've been literally impossible without them.
Tom
I hate stories like this.
I would just start from the battery and verify power at the source, check to verify the battery terminals are good and clean, both cables terminations are clean with a good solid ground .... then trace the + accessories tap.... Possibly there are some fuses you didn't see, or a fusable link?
I had that happen on a Toyota and the battery shorted internally. It was deader than dead.
Good luck, let us know what you find.
1 Post
slivan,
Sorry to hear of your misfortune. Always look to the last location of repair in cases like this. The odds that an incident such this happening and it being something else are astronomical. It sounds like it may be the wiring down by the starter or the starter itself. Make sure nothing loosened up and cross-connected.
Check all the obvious stuff like battery cables, ground straps, etc, but also check the plug connection for the ignition switch that goes through the firewall to the fuse block. This can work itself loose and nothing will work. We have had several cars towed in for this.
1 Post
I agree with Chris about those G'damn firewall plugs. I almost went crazy trying to find a problem with half of most of the things inside the cockpit. Like one window, one interior light, one turn signal etc. The damn thing was still together but not making full contact.
The new starter tests out fine, all connections were in tact. Interestingly, when the key was turned to the accessory position ( I thought miraculously it would start up...) the warning lights and blaupunkt blue on light lit up. Turn full on try to start and lights out, nothing. ALmost like a little residual power. Reinstalled the starter, full 12V at the battery and starter. Have voltage the block fuses 16 thru 20, direct from the battery to block. Digging in now, gonna check that firewall plug.......
no alarm..... no 12v to the hazards but have 12 V to the #30 pin the 6pin feeding the ignition switch. New electrical portion of the ignition switch on the way....
