Just bought my first Porsche, 77 930 ????s
Isn't my differential suppose to be LSD, I turn one wheel and the other goes oposite direction or does it take a load to engage? What ratio should it be? Its a 915 4speed. It has been barely driven in last two years, so I am in the process of detailing underside of car and changing all fluids, rebuilding calipers, checking sparkplugs and replacing a bunch of little items such as oil temp sender, pressure sender, belts etc etc. Considering splitting turbo and replacing oil seal, any special tools neede? I am sure I will have a bunch more questions in the next few months. Thanx in advance, Jamie
From your description you do not have an LSD.
If the option code sticker is still on the bottom side of the hood and you see number 220 on the list it origonally had a limited slip differential and someone changed it for a regular open one.
I've never taken the turbocharger apart.
Mine came with 3 options,
Limited Slip Diff - $370.00
Sport Seats Left and Right - $255.00
Electric Sliding Sunroof - $710.00
with a total retail price of $29,924.00 back in 77.
now post some pics of your "new" 77.
I just confirmed from PO, that my diff has Quaife.......
Internals, torque biasing diff. I quess it only engages under load, is why when I turn my rear tire the other goes opposite way. Can anyone else confirm this is a character of Quaife diff.? Thanx, Jamie
