Fuel pump(s) fuse wiring
Can someone please indicate whether there should one or two output wires from the fuel pump fuse, please? Should the end of the wire(s) be soldered solid and then inserted in the fuse holder or is just a twisted wire(s) OK? My fuse seems to run warmer than I'd like, tho it has never blown. Thanks, John
There is one wire. It was dipped in solder and should be re-soldered if cut. You may want to try the Lee Rice fuel pump/head light/AC wiring improvement from the Pelican Board. I didn't use a factory 3 fuse holder, but an in-line spade fuse holder I had for each pos wire going to the relays.
