Big Reds Upgrade - A "Slow'N'Rusty" Pictorial
Well Gang *finally* got my Big Reds upgraded in the front *only* with new 993TT rotors. This is a project I pieced together and took much longer than I thought it would, due to the fact that some idiot before me (who worked on the car prior to my ownership) had rounded off the inner portion of the 10mm Hex bolt on one of the calipers and I had weld the socket to the bolt. Then tightening \ torquing the aluminum hat to the 993 TT rotor, I was rushing and the torque wrench slipped and I had to be rushed to hospital and got 5stitches on my pinky finger, from slicing it open against the sharp edge of the new rotor (out of comission for 2 weekends on that stupid error!), also chipped the bone too on the joint...nice one!
I also completely refinished and repainted the 993 calipers with high temp paint and painted the "PORSCHE" logo as well, so more time there. A week there or so.
I also had custom "DOT" front stainless braided brake lines made for me for the front (that took another week).
In the rear I installed a set of DOT rear braided steel lines I bought from Pelican. At the same time I installed new Zimmerman rotors and shoes for the e-brake and PBR Axxis pads in the rear. In the front I am using EBC Red Stuff pads.
With my 17" HRE wheels I could easily run a 335mm rotor in diameter. The 993 TT rotors I am running are 321mm in diameter versus 303mm for the stock 930 rotors. The 993TT rotors are also thicker have a better vain design for cooling and have a much larger pad contact area. They also only 2.5lbs heavier than the stock 930rotor (16.5lbs vs 14lbs).
Ok enough blabbing...here are the pics...
993 TT Calipers when I first bought them (came off a race car):
![](https://pic20.picturetrail.com/VOL86/504386/17431139/270972447.jpg)
After I refinished them:
![](https://pic20.picturetrail.com/VOL86/504386/17431139/270972452.jpg)
993 TT Rotor left vs 930 Stock Rotor:
![](https://pic20.picturetrail.com/VOL86/504386/17431139/270972448.jpg)
![](https://pic20.picturetrail.com/VOL86/504386/17431139/270972459.jpg)
Differences in diameter and weight respectively:
993 TT Rotor:
![](https://pic20.picturetrail.com/VOL86/504386/17431139/270972461.jpg)
Stock 930 Rotor:
![](https://pic20.picturetrail.com/VOL86/504386/17431139/270972464.jpg)
Differences in pad respectively, the 993 TT pads have a much larger surface area and do not have the wear indicators like the 930 pads, so my dash on my light is now always "on" (might have to pull the bulb)
![](https://pic20.picturetrail.com/VOL86/504386/17431139/270972450.jpg)
Stock 930 brakes, still impressive:
![](https://pic20.picturetrail.com/VOL86/504386/17431139/273450165.jpg)
But these are the "daddy":
![](https://pic20.picturetrail.com/VOL86/504386/17431139/273450171.jpg)
I finished everything tonight at 9pm after 2+ hours of bleeding!! Thought it would never end and buttoned everything up, and took the car for a much deserved drive, the pedal feels excellent, but I will re-bleed on Staurday as I still feel there might be a few straggler bubbles in the system. I am running ATE Blue brake fluid. If you guys want better daylight pics and some pics of the custom front braided lines please let me know and I will snap a few.
Total cost of the entire project:
1) Big Red 993 TT Calipers with 930 caliper \ hub mounts - bought used
2) 993 TT rotors & aluminum hats - bought used not many miles on them
3) New 993 TT EBC "Red" pads
4) New Zimmerman rear calipers
5) New Rear Axxis PBR pads
6) New Rear brake shoes
7) New Front and Rear DOT approved braided steel brake lines
8) ATE Brake Fluid
Total: $1970
Best Regards - Yasin
993 TT Rotor:
Stock 930 Rotor:
8) ATE Brake Fluid
Total: $1970
As usual, 'Rusty...you da man! Great work!
And for the record, Carib is one of my all time favorite beers!!!! It's hard to find here in NC, so now I gots the shakes and I'm drooling!
Take the old pad's connector and cut off the end leaving 25 - 50 mm of wire (1-2 "). Then solder the wire together and plug it into the wiring harness and tie it up. The system works on a complete circuit that gets cut when the pad wears the connection and causes it to be open.
Thanks for the comments and feedback guys. When I was wrapping up last night, I actually thought about spade connecting the two wires together for the sensor which means I could re-use them later if need be.
My best - Yasin
My best - Yasin
Yasin, you could fit the front calipers to the rear.
Try not to rush any work in the future.
What paint did you use? All my calipers could do with smartening up on both my P cars.
The rotors are actually considered 322mm not 321 no biggie also the factory pads have provisions for the wear sensors. What pads are you using?
Yasin
Here's a question: When people say that they are upgrading their 930 with the big brake kit, do you upgrade just the fronts or both the front & rear? I was pricing the kit in Performance this morning and I was wondering what the answer to this question was...
