911 Turbo (930) Forum 1975-1989
The car is broken again ....... no power is getting to the wheels ....
Old 08-12-2007, 07:57 PM
Maxx1
Maxx1's Avatar
Unhappy The car is broken again ....... no power is getting to the wheels ....
... it sounds like the transmission blew up, none of the gears work, just lots of racket. Funny thing is, I've been driving it really easy.
Once I take a closer look, I'll post more about it....
Old 08-12-2007, 08:27 PM
Maxx1
Maxx1's Avatar
The right rear axle is flopping around at the wheel. That is at least good news that it's not the tranny. I wonder what could have let go under that boot
Old 08-12-2007, 08:30 PM
Gary R.
Gary R.'s Avatar
CV joint let go would be my guess. Easy fix, check all your boots while you're down there.
Old 08-12-2007, 08:37 PM
BrianKeithSmith
BrianKeithSmith's Avatar
May as well check them all...
60 ft/lbs
Old 08-12-2007, 09:19 PM
Maxx1
Maxx1's Avatar
Something I noticed about this car... the guy that restored it didn't tighten things up very well.
1. Lots of noise coming from the rear. Loose top shock nut.
2. Spark plugs were all barely snugged in place. One was only finger tight.
3. Steering wheel play ( up and down ) loosened up a lot last night. I still haven't looked into that yet.
...now this CV joint fell apart. I am going to have to go over every nut and bolt on this car .... I'm almost afraid to drive it anymore.
Old 08-12-2007, 09:21 PM
BrianKeithSmith
Don't strip those bolts out when you check them....
If they look rounded, remove them and replace them.
Old 08-12-2007, 10:18 PM
Noah930
Noah930's Avatar
Jeesus. Sorry to hear of your troubles, Maxx. Sounds like you're having more than your fair share. Keep with it, though. The end result is more than worth it.
Old 08-12-2007, 10:23 PM
Maxx1
Maxx1's Avatar
I am just hoping nothing got torn up when I was trying to get the car to move. I guess I will know later in the week when I get it torn apart.
Old 08-12-2007, 11:29 PM
A930Rocket
A930Rocket's Avatar
The car looks great. Don't give up. Keep working on those little problems and you'll have a better car shortly.
Did the bolts come loose or the CV joint fall apart? Either way it's an easy fox.
Any questions, let us know.
Old 08-13-2007, 09:14 AM
Maxx1
Maxx1's Avatar
I don't know yet.... I think the whole thing fell apart since I can move it about 2" any direction. I'll have to check all the other joints as well now.
Thanks, I'll probably have a few questions.
I have to crawl under there tonight and see if I can figure out how to get the boots off. I am glad this happened at 15 mph rather than 115 mph.
Old 08-13-2007, 09:23 AM
Dknebes
Dknebes's Avatar
Has anyone had a axle or cv joint let loose at high speed and what happens at that point?
Old 08-13-2007, 10:08 AM
sand_man
sand_man's Avatar
Consider yourself lucky nothing was destroyed under there, when it broke/came loose! I've heard it can get gnarly when an axle lets go under speed!!!
Some good info here, on the proper hardware to use to keep them tight! With the Schnorr serrated/bevelled washers, new bolts, and the half moon plates, mine haven't budged, and I check them whenever I'm under for any reason!
If your engine/tranny was out for some service (previous owner), it's possible that the bolts have worked themselves loose...
Hardware info on page 2 of this thread:
http://forums.pelicanparts.com/showthread.php?t=222537
Old 08-13-2007, 10:11 AM
sand_man
sand_man's Avatar
Old 08-13-2007, 11:45 AM
Maxx1
Maxx1's Avatar
Thumbs up
Wow! That is a goldmine of info on this problem. Thanks a million.
Old 08-13-2007, 09:39 PM
BrianKeithSmith
60ft lbs for those bolts you display. FWIW - I don't use any locking washers on mine, SandMan swears by his, but I've never had an issue with them loosening and I track my car 100% of the time.
Just get the good stuff on grease - Mobil1 Synthetic - 1 or 2 tubes.
Quick Reply: The car is broken again ....... no power is getting to the wheels ....
