Rear Seat Delete/Conversion
I did that same kit on my car about a year ago. I down loaded an old instruction sheet that I found on pelican. It wasn't the right instruction sheet but it helped me get started. The problem with the kit is that there is a lot of overlapping of the carpet so it makes the jigsaw puzzle that much harder. It took me about a weekend, other than getting so frustrated so bad I almost cried (only once ) it wasn't too bad.
I also put down some dynomat that has the aluminum skin to help with sound and heat.
PM me if you want that PDF, some of the carpet in the kit is different from the instructions but it helps.
