brians WUR solinoid
brians WUR solinoid
My mechanic though he heard that brian leasks WUR solinoid set up would not work with Crank fire ignition. Is that true. I have his WUR in the car now and running rich in midrange and was going to install the solinoid set up.
Thanks John
Thanks John
I have Electromotive XDI ignition in mine (crank fired) and Brian's RPM solenoid. I spliced into the tach line from my Electromotive controller and whenever I put the turn signals on, step on the brakes, turn on the lights, my tach needle bounces all over the place....like I'm getting some sort of electrical interference. I checked for good grounds and power source, all is good.
The switch itself appears to be working fine (no irregularities on AFRs that I can see). I just think I either need to splice into a different part of the tach wiring or try out the the number 21 pin (advance output) on my XDi unit. I'll verify if this voltage from this pin is sufficient for driving a tach signal by running a few tests. I plan to play with it this weekend.
I tapped into my blk/violet tach wire. It all works fine, except my tach jumps once in awhile too. Does anyone know how to fix this? Thanks John. 911rudy are you saying to diode isolate the wire so nothing feeds back into the tach for the solinoid tach wire?
From MSD, there is something called a "Tach Splitter". Part number 8911... I wonder if this would help prevent the feedback?
http://www.msdignition.com/media/images/8911.jpg
sand-man you are thinking of a resistor with values. A diode only lets a + or a - signal go one way. They are measured in amps.
sand_man, you can get diodes at radio shack. I dont think that will help . It might cause resistence in the signal. I am going to email Brian leask and see what he recommends.
What I'm stumped on is how simple the wiring is for this solenoid, yet how trying to splice into the tach wiring causes the tach needle (in the car) to go crazy whenever another elctrical source (headlights, brake lights, turn signals, etc.) is engaged. Just driving the car around with no other elctrical source running, the tach is fine.
How is it picking up the feedback and/or interference?
1 Post
It sounds like the new wire has opened another leg for the entire circuit to follow under some circumstances. Take the amp data that comes with solenoid and go to Radio Shack and tell them what you are trying to do. The diode simply creats a oneway gate so that leg can't become an alternate path or allow any interference back through the tach circuit. It may not work but a pack of four diodes is not much.
