How have I screwed up my brakes?
#46
Originally Posted by Kirk930
Hi Rod,
Would a warped hub/improperly seated bearing not show as a vibration when driving without braking. If so, then it must be the rotor again...........maybe I got two warped ones??? Doubtful though.
I've since replaced the rears too.
The greatest amount of vibration is induced by thickness variation.
#47
I use the same Hawk pads and rotors....work great. I put new rotors on the rear...Zimmerman....and the right hand rotor was slightly warper right out of the box!...turned it a touch...perfect
#48
Hi Rod,
No, the brakes still have the pulsation.........I've just been living with it.
