Wow! Eddie Bello Is Back..Pics of His New 1153whp 964!!
#61
See this is the main issue. This engine is being presented as a daily driver (not a race engine) that runs crazy trap speeds of 150 +mph, 1.5 bar on pump 93 octane gas (sorry not familiar with the winter blend), 750BHP+ at 1 bar on pump, 1200BHP+, etc...
What I see is a lightweight narrowbody 2700lbs at best 964 with probably 700+BHP at 1.5-1.6 Bar (you don't need more for that trap speed and weight) that has been run on a chassis dyno (that no one has seen yet) with hardly any load on the engine. As I said earlier even a dyno run won't mean much.
Simply put, you could probably achieve that sort of hp at 2 bars with all sorts of cooling gizmos, at 9000 RPMs but you cannot have both things, a street engine that has any torque below 5K RPMs since you need massive turbos for that HP on an aircooled engine, and an engine that lasts more than a few QMile runs..
If they are moving to road/track racing, this is when they will discover what real HP they have, and I can bet it will be closer to 500HP than 1000HP.
#62
#63
Originally Posted by KPG
Maybe it was running a Boost Controller...otherwise I dont think it is possible.... At least you're consistent Jean, I thought you were only skeptical of the waterpumpers... Kevin
The waterpumpers will maybe one day go beyond that 140mph posted trap speed, they just need a few more years that's all
#66
My engine has about 5% larger displacement, aggressive cams and almost everything that can be done to an aircooled engine and shows 300HP per absolute bar with pump fuel, that is like a 3.8 ltrs 964RS efficiency, the 964 3.6 ltr engine had 285HP/Absolute bar. At 1 bar of boost that equates to about 600FWHP. How can a 3.6 engine have almost 150FWHP more than my larger engine at the same boost levels...Of course assuming that my tuner is not a newbie, which judging by the performance he is not.
IIRC, I believe it was a 9.15 @ ~150mph that Eddie ran, on video, which was proven without a doubt (just waiting for the claims the video was sped up ). I think the guy has some idea what he's doing. It would definitely be nice to see a dyno sheet but oh well. 22psi on pump gas isn't that unbelievable. There are plenty of things like water injection, aftermarket EMS, etc that can allow you to fine tune things to reach boost pressures close to that (even on an "inefficient" 2v motor) on pump gas. I'd tend to think that 22psi would probably be about as high as you could go on pump though because of the inherent inefficiencies with these 2v motors compared to the much more advanced 4v stuff on modern cars today.
#67
Originally Posted by Porschefile
Your twins are CONSIDERABLY smaller Jean. It's as simple as that. Even on low boost, that is a substantial amount of airflow volume. Say you have 2 cars, one with 2 350hp turbos and the other with 2 600hp turbos. At the same 1bar of boost, which makes more power? j/k
Sorry I have to correct you as you seem misinformed.
My turbos are the same compressor size of a GT30, so not that much smaller. I have the data from a twin turbo sister engine to mine with GT35Rs and know what output they have at 1 Bar, and at 1.5 Bar as well. I am not comparing to my engine, maybe Bello knows better, but I would give him 10-20hp over my larger sized engine at the same boost if he is a genius, not 150, at least not on an engine dyno and definitely not on pump gas.
But that does not really matter, since it is not the issue at stake. A larger turbo at 1 bar and same RPMs will give you less torque not more as the turbine takes more time to spin the heavier compressor.
The debate is not about whether Bello can run those numbers, I said that long ago, I know he can, the debate is whether this car can have that HP at that boost level and whether this car can have 1150rwhp while being a nice drivable daily car as pictured. They are mutually exclusive, and anyone who has pushed the envelop far enough will know that the cams that you need, the size of the turbos, the exhaust and the intake system do not make a combo for the street.
As to the 9.15s car, Bello can also claim what he likes but I have first hand information that his car did not even have a stock steel floor panel, it was cut out and replaced and covered by lightweight material, nothing was stock on that car and it did not weigh North of 1900lbs, again, it is not the subject of the conversation. I am very very HAPPY that an aircooled 911 car got there thanks to him!! Believe me.
Does that take any merit out of his record? Of course not. But it also does not mean he had 1000rwhp, which is what I am interested in.
I hope this is now clear, I would not like to repeat myself over and over again, I am just saying keep the claims and data real, get the credit for the runs from everyone here, and that video is not proving anything more than a lightweight 500fwhp car blasting from God knows what speed to what speed, and maybe at its highest boost setting, not at 1 bar. Or maybe not, who knows? '
Dyno charts? Please not.
#68
Someone needs to build 4V heads, ala 959, without liquid cooling, and billet grind a cam to suit
interesting off topic article: http://www.pistonheads.com/doc.asp?c=52&i=15223
#72
It sure is running a boost controller, either via the EMS or an EBC, and this is exactly why the engine would blow at 1.5 bar on 93 octane (maybe not the first few times), the ECU is not there to pull boost back in case of detonation, and it WILL happen with low octane.
#73
Originally Posted by origyns
which is an inground DynoJet that I'm 99% positive is nearly impossible to manipulate)
#74
Since you seem to be such a skeptic, and Eddie saw this thread as well we were reading it together, he said if you were to ever come to NJ/NY he will personally take you to the dyno (which is an inground DynoJet that I'm 99% positive is nearly impossible to manipulate), and we'll run the car for you on the dyno.
I will be more than happy to go see you and Eddie in NY, I go quite often, just don't expect me to waste anytime on your dynojet. We'll weigh your car, slap an AX22 there and check out your boost guage and then bet $50k if conditions are met as you claim on this thread and video, how much fun is that? A 3100lbs 964 at 1 Bar and a 2 shift 7 seconds 60-150mph, no NOS, deal? You will need to put a bank guarantee though. We can get a crowd of my buddies there and yours too if you wish for the record.
Careful because once you say ok, you don't pull out, you will embarass yourself.
Oh by the way, we're both laughing hysterically about the estimations of the weight on the old car.
My intake? Stock CIS stuff but I had it polished with stock but ported headers, and 3 angle valve job, is that enough for 1000rwhp you think? Oh and I have a huge intercooler on which I put some ice cubes when I run
Do some research.
#75
Formula One Spin Doctor
Origins, with all due respect, that is the most naive statement concerning dynos that I have ever heard. Dont get me wrong, unlike Jean I think they are a valuable tool when combined with track times, 60-130 times etc to give a good estimation of power, but they are capable of being manipulated very easily. Just start with correction factors and go from there....Kevin
Do a dyno shootout or race and get it over with ...
