Blownsix 930 Intercooler Pic
Looks great! How is the fit? Did you have to do any modifications to either your car or I/C, or was it plug-n-play. What did you upgrade from?
Thanks,
David
1986 911 Turbo
Thanks,
David
1986 911 Turbo
i upgraded from a b&b unit as i wanted the updated c2 bypass valve and the long neck design. this unit is the newer variation which Blownsix had already worked out their fitment issues, it uses the stock boost pipe and bolts up quite easily.
