electromotive distributorless ignition system
Has anyone installed one of these systems, or looked into it? My mechanic likes them. The electromotive system uses coils to produce a direct charge to the spark plugs with no distributor or points at all. The spark is about ten times longer in duration than from a standard CD unit, and the timing is accurate to 1/4 degree. Set it and forget it.
What I am wondering is if this longer spark helps compensate for not having Twin plug ignition setup. Also how much horsepower can be gained from a longer burning spark.
And if anyone has tried the setup or knows much about it, are there advantages to playing with the advance curve. I would like low end power. Does the timing curve make much difference in this regard?
"What I am wondering is if this longer spark helps compensate for not having Twin plug ignition setup. "
No ignition system is going to compensate for the fact that the 930 has a hemi head with the sparkplug located on one side with a flat top piston with not provisions for a squish area. Twin plug is a must for achieving peak power.
Most power gains are from having optimal timing at all operating conditions throughout the entire RPM range. The stock mechanical advance is not going to give you that.
I had installed the Electromotive HPV-1 in my 930. It is single plug. I LOVED it. The exhaust note sounded better than stock, and I swear I could feel a difference (butt dyno). I did not dyno it, so I have no idea if it did gain any HP. I would not hesitate again to buy the HPV-1, BUT and I stress but..... I have heard horror stories about the TEC-2 and the TEC-3 on turbo cars. IMHO, I would stay away from the TEC series on a 930 motor. I have also been told that the older HPV-1 units are much better than the new stuff that is coming out from the company. With that being said, if you want to call me, I can talk you through it...
BTW, I still have my HPV-1 and it is for sale as I am going full EFI, so I will not be needing it anymore...
Is Toyota racing making a multiple coil system(one for each plug) for one of their racing teams(I seem to remember Baja racers) that has been effectively used on non Turbo track Porsches??
COP (coil-on-plug) is nothing unusual.
I have installed them onto several cars and they're great: no spark plug wires, clean look etc. But they require standalone engine management and one has to choose really carefully what coil to use, they have vastly diferent output characteristics.
As far as TEC EMS, TEC2 is NOT suitable for turbocharged cars, TEC3 is but I heard also some of it's flaws.
Best ign. for 911 is twin-plug with COP's, that enables fully sequential ign. and individual cylinder trim plus overcome of the big combustion chamber design that requires two plugs to compensate flame speed.
"Best ign. for 911 is twin-plug with COP's,"
As long as you choose performance coil per plug from a racing ignition system, I might agree with that. The factory COP setups are small and weak inductive style ignition. I would rather run a dual distributor with CDI than an OEM factory COP.
Originally Posted by Geoffrey
.....As long as you choose performance coil per plug from a racing ignition system, I might agree with that. The factory COP setups are small and weak inductive style ignition. I would rather run a dual distributor with CDI than an OEM factory COP....
There are some OEM coils that work, but cheap ones have usually weak secondary coil output. And most suitable OEM ones are passive type, not active.
One type of coils that are powerful enough are VAG early 1,8T passive ones (w/ 3 wires, without internal switching circuitry). They are good enough for 150hp per cylinder but are bit uncomfortable to mount because of their shape.
Hi, i know this is an old post. I was wondering if you have the HPV-1 available. I have had mine in my car for years and it has burnt out on me. Called up Electromotive and asked if they can repair it and was told they do not. So i have been trying to find one. Any information would be Great. Did you ever get to EFI your car? All the Best, and thank you in advance.
Regards,
Nick
Regards,
Nick
