So what is the best replacement for say my car which will have a B6 half bay, tial wastegate and custom exhaust after turbo, and running 13psi. Just something that bolts on with minimum mods etc.
Just depends on where you want the power and how you want it. If you are running less than a bar then consider the K27S. It spools faster than snot and provides good gains.
Thanks Stephen. Would the K27S still be ok if I was running 1.0bar. I'm pretty happy with the power range now, perhaps a little lower in the rev range for boost.
