Need help -930 Engine into a 911SC-
Hi
I have installed the engine in the car (1983 Turbo engine into a 1978 SC car)
Everything looks good but one thing.
The 14pin connector between the engine and the car,is the same but the wires inside the connector isn't matching. Seems like Porsche placed wires for the same function in different places on SC - turbo. The connector is the same.
Does anyone have electrical diagrams showing the difference?
Does anyone have a car(911 SC) with a Turbo engine installed?
If so would you be willing to take a look at your car and see witch pins in the connector, have been switched to make it work.
Grateful for all help.
Thank you
Knut.
Thank you
Knut.
I've done it to my own car but it was a long time ago. I still have the car and could look for you if it helps. Ijust compared both wiring diagrams and used the onesI needed such as oil pres and temp etc. I used one pin for my over boost cutout switch. Ifollowed it up to the front and disconnected it then wired it up to the fuel pump relays.
I would think you can figure it out with what you have here, if not send me a email tomorrow and give me a number I can call you at. I should be able to walk you thru it.
This is the 14 Pin Male in the '77 engine bay. The pin assignments are as follows:
1. yellow - starter Kl.50
2. brown/white - To a harness below the shift lever
3. green/black - Oil temperature Instrument
4. green/red - Oil pressure Instrument
5. green/yellow - from ignition.( Kl.15 ) to backup light switch
6. gray - backup light switch to lights
7. blue/yellow - To fuse on panel in engine bay
8. green - To a harness on the trunk floor
9. green/white - Oil pressure idiot light
10. red/white - Thermovalve
11. blue - alternator control light Kl.61 ( or D+ )
12. free
13. black/yellow - power source for the fresh air blower
14. red / source from alternator Kl.30 or B+
12. free
What can I say...
You guys are THE BEST!!!
I think I will be able to make it work now.
Thank you so much Tripster.
Really helps![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
2 Years of building the car... Finaly I get to start her up!Only thing stoping me is this lttle thing.
No stopping me now that I have your help![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
"Custom" brakes. Bilstein Coilover's. dp-motorsport engine.Turbo 2 body kit w/RS3.8. Life is good
Really helps
