Can I use 964 dual distr on 930?
Is there a gear out there to make these things spin the right way?
Planning on using for efi so not concerned mech advance becomes retard...
If you need to rotate the distributor the opposite way, buy the factory porsche gear and press it on the crank. They are interchangable. Swapping the gear on the distributor is more involved since they changed dimensions of the distributor between 930 and 964/993.
As far as the distributor itself goes, you'll want to ensure that proper rotor phasing still occurs, although at 6500rpm it isn't going to be the issue it is at 8000rpm.
