911 Turbo (930) Forum 1975-1989
engine in finally and it will not start
Old 10-07-2006 | 07:46 PM
kens911's Avatar
kens911
here is where I am now
Old 10-07-2006 | 07:48 PM
sand_man's Avatar
sand_man
Brave man you are, Ken!
Old 10-07-2006 | 07:56 PM
kens911's Avatar
kens911
that what every body said when I cut holes with a sawzall in the side of a car with a fresh paint job LOL but it's be good when I'm done. it still has one more trip the the body shop. They didnt buff any thing out, wanted to wait until I had it all put back together so they could repair any dings or scratches from re assembly. then it has to go back to the shop where I got it so it can be inspected and retitiled.
Old 10-07-2006 | 09:19 PM
sand_man's Avatar
sand_man
about the ground...did you connect the braided ground strap from the tranny nose to the under-carriage?
Old 10-07-2006 | 10:41 PM
kens911's Avatar
kens911
yes it's connected. I have a hot leg to ground someplace. A lot of the stuff up front isnt connected yet so possibly there is something up front I'm going to finishe putting it all together. the go back and look for the problem. still have to wire up the new lights, make a new windshield washer esevior etc.
Old 10-07-2006 | 11:32 PM
A930Rocket's Avatar
A930Rocket
Do you have spark out of the coil and plugs?
Can you disconnect your gas supply line at the engine, connect a clear hose to a gas can, turn it over and see if you are getting gas?
Old 10-07-2006 | 11:56 PM
kens911's Avatar
kens911
havent checked yet was going to put the timing light on it to check that when I found that it was grounded, which if dont solve that nothing will work
Old 10-08-2006 | 01:55 PM
slivan's Avatar
slivan
use the inductive light to make sure there's spark as you turn the motor over, if so depress the air meter plate to get things going as you crank the motor, you should hear the injectors 'peeing' some fuel. Took me a little bit of fiddling around to get mine to fire after the rebuild.
Old 10-08-2006 | 08:27 PM
kens911's Avatar
kens911
oh ok i'll try that thanks!
Quick Reply: engine in finally and it will not start
