911 Turbo (930) Forum 1975-1989
Pre 91 Engine into a 964T questions
Old 08-07-2006 | 12:43 PM
Earlierapex's Avatar
Earlierapex
Default Pre 91 Engine into a 964T questions
Cross post from 964t board:
I've got an 89 930 cabriolet that just isn't the right car for this crazy engine i've had stephen build (roughly 600hp). Duh...
Anyway, I'm going to swap it into a 964t. Seems pretty logical as the 964t uses the same engine.
Can you guys think of any catches I'm going to have? I've thought of a few:
1) power steering - anybody tried an electric drive for this rather than using the cam? what does it take to swap to a manual steering box?
2) cooling (what's the best front oil cooling solution for a 964t? - is the fender unit sufficient for 600hp?)
3) ABS - is this a totally seperate box from the engine?
4) transmission - it's coming out of an 89 with the G50/50, I assume this is a direct swap into a 964t 5spd (is that the g50/50 too?) I"m leaving the g50/50 in the 89 and using the one in the 91.
Anything else ya'll can think of? Thank you!
-dc
Old 08-07-2006 | 12:49 PM
Geoffrey's Avatar
Geoffrey
1) You can buy an RS America power steering rack and bolt it in. Or you can run the GT3R power steering pump from PMNA which has only +12v, Ground, and an alternator connection.
2) You'll need a secondary oil cooler and will have to fab up something.
3) ABS is separate and will function fine
4) The C2T has a G50/52 and you'll need to change the flywheel, starter ring gear and the pressure plate. The starter is completely different between the 930 and 964 chassis.
Old 08-07-2006 | 01:01 PM
Earlierapex
Geoffrey,
As always, very helpful. Thank you.
-dc
Quick Reply: Pre 91 Engine into a 964T questions
