911 Turbo (930) Forum 1975-1989
Aftermarket Intercooler Water-spray kits?
Old 08-03-2006 | 12:22 AM
ProtoCab's Avatar
ProtoCab
Default Aftermarket Intercooler Water-spray kits?
Anyone running an intercooler water spray kit on their big HP/high boost motors?
I came across this device which would be suitable for triggering a water spray pump:
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
"Boost Activated, Boost Level Adjustable.
Commonly used for automatically turning on secondary items such as additional injectors, intercooler misters, water injector, nitrous."
Old 08-03-2006 | 12:48 AM
SoFast's Avatar
SoFast
Cool little device!
Old 08-03-2006 | 10:28 AM
sonny1's Avatar
sonny1
I got a the "Inteligent Water Cooler Spray" kit, it is a mini computer that control the spray based on intercooler core temp. and boost pressure, it is made in Aus., you can go to the Autospeed web site and do a search in there, works perfectly. I have a new extra unit which I bought for another project, but this never come to be, let me know if in need, cheeres, Sonny.
Old 08-03-2006 | 10:37 AM
sonny1's Avatar
sonny1
Go to www.autospeed.com , or, autospeed.drive.com.au/cms/article.html?&a=0527&p=1
cheers, Sonny.
Old 08-03-2006 | 10:45 AM
sonny1's Avatar
sonny1
Note,
This system, requires careful attention on how you wire it, at first it did not work for me, then I found out that I wired it incorrectly! it works!, cheers,Sonny.
Old 08-03-2006 | 02:34 PM
nathanUK '81 930 G50's Avatar
Now if they did one that was Normally Closed we could use it and adjust for a safety over boost fuel cut out instead of just grounding the wire as some people have.
Quick Reply: Aftermarket Intercooler Water-spray kits?
